Grade B returned device
Looking for AirPods, but want to make your money go further? Try one of our Grade B devices and you’ll find amazing deals on some of the latest and greatest devices.
12 months warranty
Good condition, showing small signs of wear which includes, but not limited to, small/fine scratches and marks.
Beats Fit Pro is equipped with comfortable, secure-fit wingtips that flex to fit your ear. The universal wingtip design was put to the ultimate test by athletes of all kinds so you can trust these earbuds will stay put through work days and workouts. Complete with pressure relieving vents, you can comfortably wear these earbuds all day long.
Three soft silicone eartip options make it easy to find the right size. The Fit Test setup for both Apple and Android helps ensure proper fit for a customized acoustic seal and optimal performance.
Surrounds you in sound
Beats Fit Pro is engineered to deliver powerful, balanced sound via a custom acoustic platform that stays with you through your daily activities. A proprietary, dual-element diaphragm driver resides within a two-chamber housing, resulting in clear sound with outstanding stereo separation. An advanced digital processor then optimizes audio performance for loudness and clarity, while simultaneously ensuring clean noise-cancellation. Beats Fit Pro supports Spatial Audio with dynamic head tracking for immersive music, movies, and games. Dynamic head tracking uses gyroscopes and accelerometers to adjust the sound as you turn your head, for a multi-dimensional experience that makes you feel like you're inside of it. -
Hear what matters
With two distinct listening modes, you are in control of what you hear. Fully adaptive Active Noise Cancelling (ANC) uses real-time audio calibration to continuously pinpoint unwanted external sounds and optimize sound output. When you need to be aware of your surroundings, easily switch to Transparency mode. The external-facing microphones capture environmental and ambient sound around you to mix in with your music. Now, you can always choose the listening mode that fits your needs. -
Equipped with Apple H1
Powered by the Apple H1 chip, Beats Fit Pro is ready to help you handle whatever the day throws at you. Instantly one-touch pair with all your Apple devices. When you switch from your iPhone to your Mac or iPad, Automatic Switching re-routes your audio. Audio Sharing with another pair of Beats headphones (or Apple AirPods) means you can easily share your favorite music with all of your friends. -
Power your day
The earbuds have up to 6 hours of listening time with 18 additional hours provided by its pocket-sized charging case. That means that Beats Fit Pro gives you up to 24 hours of combined playback. With ANC or Transparency mode turned off, you'll get up to 7 hours of listening time. If you need a little extra juice, 5-minute Fast Fuel charging gives up to 1 hour of playback when battery is low. A battery that lasts? That's a power move. -
Loud and clear
With a built-in accelerometer and Class 1 Bluetooth technology, Beats Fit Pro can detect when you're speaking to help you sound your best. Dual beamforming microphones pinpoint your voice while a digital processor cuts out external noise and wind, so your voice is clear and easy to hear. -
Works with Android
Beats Fit Pro easily connects to Android devices via Bluetooth right out of the box. With the Beats app for Android, you'll get enhanced features like one-touch pairing, customized controls, battery levels, firmware updates, and a Fit Test to help you get the best sound and fit out of your earbuds.
- Beats Fit Pro - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Compatibility
- iPhone, iPad, iPod, Android phone, Mac, Android tablet
- Recommended Use
- Portable electronics
- Additional Functions
- Wireless audio sharing, transparency mode, spatial audio with dynamic head tracking
- Volt yellow
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Active Noise Canceling
- Microphone Operation Mode
- Beamforming
- Controls
- Programmable button
- Intelligent Assistant
- Siri
- 1-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- Compatibility
- Dimensions & Weight Details
- Charging case: 6.2 cm x 6.2 cm x 2.85 cm / 55.1 g
- 2.4 cm
- 3 cm
- 1.9 cm
- 5.6 g
- Volt yellow
- Recommended Use
- Protection
- Sweat-resistant, IPX4, water-resistant
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Sound Output Mode
- Stereo
- Active Noise Cancelling Technology
- Adaptive Active Noise Cancellation
- Apple H1 chip, Fit Test
Microphone
- Form Factor
- Built-in
- Beamforming
Remote Control
- Controls
Tracking
- Sensors
- Accelerometer, gyroscope
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Siri
- Included Accessories
- 3 pairs of silicone ear tips, charging case, USB-C to USB-C charging cable
- Cable Details
- USB-C to USB-C cable
- Bluetooth Class 1
- Battery
- Headphone battery rechargeable - Lithium Ion
- Run Time (Up To)
- 7 hour(s)
- Run Time Details
- Continuous playback (noise cancelling OFF): up to 7 hours , Continuous playback (noise cancelling ON): up to 6 hours , Continuous playback (noise cancelling ON / with included charging case): up to 24 hours
- Limited warranty - 1 year
