SilentWings 2 fan provides great performance-to-noise ratio and high reliability. It achieves its virtually silent operation without sacrificing airflow, and so offers the perfect balance between superior cooling and serenity as low as 15.8 dB(A).
Its secret: a unique airflow-optimized fan blade design, custom anti-vibration mounts, and a high-tech fluid dynamic bearing with copper core for greatly reduced noise and super-long life.
SilentWings 2 fan is your perfect choice for any application that requires ultimately quiet operation and uncompromised performance.
Virtually inaudible
Advanced fluid dynamic bearing (FDB) with high quality oil avoids mechanical friction. Improved modular vibration damping mounts and rubberized frame help prevent transmission of vibration to computer case and its components. -
Superior cooling
Unique airflow-optimized fan blade design maximizes cooling and reduces noise-generating turbulence. -
Flexible mounting
Flexible mounting options include screwless installation to case or components as well as mounting with screws.
- be quiet! Silent Wings 2 - case fan
- Product Type
- Case fan
- Package Content
- 3-pin plug to 4-pin Molex adapter, 5/7/12V fan power adapter
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Fluid dynamic bearing
- Rotation Speed
- 2000 rpm
- Air Flow
- 26 cfm
- Noise Level
- 14.5 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support
- 150 g
- Anti-vibration
- 3-year warranty
- Product Type
- Case fan
- Package Content
- 150 g
Heatsink & Fan
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 2000 rpm
- Air Flow
- 26 cfm
- Air Pressure
- 2.25 mm
- Noise Level
- 14.5 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Operation Voltage
- 4 - 14 V
- Start Voltage
- 4 V
- Rated Current
- 0.15 A
- Power Consumption
- 1.8 W
- Cable Length
- 45 cm
- Mounting Kit
- Included
- MTBF
- 300,000 hour(s)
- Anti-vibration
- TUV S, RoHS, WEEE
- Limited warranty: - 3 years
