Low-noise operation due to high-quality rifle bearing. The parallel arrangement of recesses on the outer side of the bearing shaft ensure uniform circulation of the high-quality oil and make the fan very quiet. Mechanical noise is minimized by anti-vibration fasteners and the rubberized fan frame. The high-quality IC motor controller reduces electrical noise sources.
Long service life
Reliable cooling for up to 200,000 hours thanks to the high-quality rifle bearing. -
High air flow
The flow-optimized surface structure of the fan blades produce more air flow in combination with smooth running. -
Simple assembly
Screwless installation makes handling simple.
- be quiet! Shadow Wings SW1 Medium Speed - case fan
- Product Type
- Case fan
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 2000 rpm
- Air Flow
- 26 cfm
- Noise Level
- 15.8 dBA
- Power Connector
- 3-pin plug
- 8 cm x 8 cm x 2.5 cm
- Anti-vibration
- 3-year warranty
- Product Type
- Case fan
- 8 cm
- 8 cm
- 2.5 cm
Heatsink & Fan
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 2000 rpm
- Air Flow
- 26 cfm
- Air Pressure
- 2.25 mm
- Noise Level
- 15.8 dBA
- Power Connector
- 3-pin plug
- Operation Voltage
- 5 - 12 V
- Rated Current
- 0.15 A
- Power Consumption
- 1.8 W
- Anti-vibration
- TUV S, RoHS, WEEE
- Limited warranty: - 3 years
