With the introduction of Shadow Rock Slim, be quiet! brings silent and premium cooling technologies to the compact PC space. Shadow Rock Slim is not simply "another space saving cooler" - it is a first-class performer meant for gaming, multimedia and graphics-intensive compact PCs.
Featuring an unrivaled price-performance ratio, matchless be quiet! low noise operation, and the distinctive attention to quality and detail, Shadow Rock Slim truly is a best choice in the compact CPU cooler category.
- be quiet! Shadow Rock Slim - processor cooler
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- Compatibility
- Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA1151 Socket
- Heatsink Material
- Aluminium with copper base
- Fan Diameter
- 135 mm
- Fan Height
- 22 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1400 rpm
- Air Flow
- 67.8 cfm
- Noise Level
- 11.5/18.7/23.7 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- 4 copper heatpipes (6 mm)
- 13.7 cm x 7.4 cm x 16.1 cm
- 729 g
- Up to 160W Thermal Design Power (TDP)
- 3-year warranty
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- 13.7 cm
- 7.4 cm
- 16.1 cm
- 729 g
Heatsink & Fan
- Compatible With
- Heatsink Material
- Heatsink Dimensions
- 161 mm x 130 mm x 52 mm
- Fan Diameter
- 135 mm
- Fan Height
- 22 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1400 rpm
- Air Flow
- 67.8 cfm
- Air Pressure
- 2.1 mm
- Noise Level
- Noise & Performance Details
- 11.5 dBA at 600 rpm , 18.7 dBA at 900 rpm , 23.7 dBA at 1400 rpm
- Power Connector
- Rated Voltage
- 12 V
- Rated Current
- 0.11 A
- Limited warranty: - 3 years
