The Pure Wings 2 family fans are unique in their class, combining outstanding reliability, silent cooling, and a great price-for-performance ratio. It's impressive how much quiet technology the German engineering team has crammed into these fans at this amazing price. They are the ultimate reason to put well-known be quiet! silent cooling in your PC if you haven't already done so.
The Pure Wings 2 120 mm model combines all of the above essential features. It provides maximum cooling airflow and operating noise levels down to a silent 19.2 dB (A). The increased air pressure makes the fans especially recommended for use in water cooling and air cooling setups.
- be quiet! Pure Wings 2 - case fan
- Product Type
- Case fan
- Package Content
- 4 screws
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1500 rpm
- Air Flow
- 51.4-87 cfm
- Noise Level
- 19.2 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- 12 cm x 12 cm x 2.5 cm
- 3-year warranty
- Product Type
- Case fan
- Package Content
- 4 screws
- 12 cm
- 12 cm
- 2.5 cm
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1500 rpm
- Air Flow
- 51.4-87 cfm
- Air Pressure
- 1.25 mm
- Noise Level
- 19.2 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Operation Voltage
- 5 - 12 V
- Start Voltage
- 5 V
- Rated Current
- 0.09 A
- Power Consumption
- 1.08 W
- MTBF
- 80,000 hour(s)
- UL, TUV
- Limited warranty: - 3 years
