TFX Power 2 300W Gold, the high-efficiency compact PSU, gives you much more for your mini or media PC. The imperative during its design was to achieve the maximum possible energy efficiency, power to support a discrete PCIe graphics card and silence without compromising quality or features.
For compact PC systems that perform well beyond the ordinary, with the best possible combination of quietness, features, reliability and super-high efficiency, choose TFX Power 2 300W Gold.
- be quiet! TFX Power 2 300W - power supply - 300 watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- TFX12V 2.4
- 80 PLUS Certification
- 80 PLUS Bronze
- 1.2 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 300 watt
- Output Current
- +3.3V - 21 A , +5V - 15 A , +12V1 - 13 A , +12V2 - 13 A , -12V - 0.3 A , +5VSB - 2 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 4 pin ATX12V connector , 1 x 6 pin PCI Express power , 2 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 4 x 15 pin Serial ATA power
- Cooling System
- 80 mm fan
- Included Accessories
- Cable ties
- Black
- 8.5 cm x 17.5 cm x 7 cm
- 2-year warranty
- TFX12V 2.4
- PSU Form Factor
- TFX
- Black
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 300 watt
- Output Current
- Efficiency
- 91%
- 80 PLUS Bronze
- Cable ties
- Cables Included
- Power cable - external - 1.5 m
- MTBF
- 100,000 hours
- Cooling System
- 80 mm fan
- Over current protection, over voltage protection, overload protection, undervoltage protection, dual 12V rails, short-circuit protection, non-modular
- TUV, CB, RoHS, WEEE, ERP
- Limited warranty - 2 years
- 0 °C
- 35 °C
- Sound Emission
- 31.4 dBA
- 8.5 cm
- 17.5 cm
- 7 cm
- 1.2 kg
- Shipping Width
- 15.9 cm
- Shipping Depth
- 19.5 cm
- Shipping Height
- 8 cm
- Shipping Weight
- 1.5 kg
