Shadow Rock 2 is a top choice among premium CPU coolers, with exceptionally high performance, well-known be quiet! Low noise operations and a category-beating price. If you are seeking the best possible mix of exceptionally high cooling performance, remarkably quiet operations, and highly attractive price in the premium CPU cooler segment, your search is over. Shadow Rock 2 simply has to be your choice.
- be quiet! SHADOW ROCK 2 - processor cooler
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- Compatibility
- Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
- Heatsink Material
- Aluminium with copper base
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1600 rpm
- Air Flow
- 51 cfm
- Noise Level
- 15.3/19.8 /25.4 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support
- 12.2 cm x 14.7 cm x 16 cm
- 1.12 kg
- 3-year warranty
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- 12.2 cm
- 14.7 cm
- 16 cm
- 1.12 kg
Heatsink & Fan
- Compatible With
- Heatsink Material
- Heatsink Dimensions
- 160 mm x 122 mm x 122 mm
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1600 rpm
- Air Flow
- 51 cfm
- Air Pressure
- 1.4 mm
- Noise Level
- Noise & Performance Details
- 15.3 dBA at 900 rpm , 19.8 dBA at 1250 rpm , 25.4 dBA at 1600 rpm
- Power Connector
- Rated Voltage
- 12 V
- Rated Current
- 0.24 A
- Cable Length
- 22 cm
- Mounting Kit
- Included
- Limited warranty: - 3 years
