The Pure Power 9 PSU series stands for peerless dependability and amazing features. Whether you are assembling a very quiet system, upgrading an existing PC, or building a multimedia or multi-GPU gaming system, your build will benefit from this PSU series that simply has a perfect combination of features, performance and quality.
- be quiet! Pure Power 9 CM - power supply - 500 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.4
- 80 PLUS Certification
- 80 PLUS Silver
- 2.07 kg
- Localisation
- English, German, French, Polish, Russian, Spanish
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- +3.3V - 24 A , +5V - 15 A , +12V1 - 28 A , +12V2 - 20 A , -12V - 0.3 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 120 mm fan
- Included Accessories
- Cable ties
- Black
- 15 cm x 16 cm x 8.6 cm
- Environmental Standards
- ENERGY STAR
- 3-year warranty
- ATX12V 2.4
- PSU Form Factor
- ATX
- Black
- Localisation
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- Efficiency
- 88% at 100% Load, 91% at 50% Load, 89% at 20% Load
- Power Factor (PF)
- 0.99
- 80 PLUS Silver
- Cable ties
- Cables Included
- Power cable - integrated - 1.5 m
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, dual 12V rails, short-circuit protection, active CLAMP circuitry, semi-modular
- TUV, BSMI, CB, FCC, WEEE, cTUVus, RCM, ErP 2014, CU
Sustainability Information
- ENERGY STAR
- Limited warranty - 3 years
- 40 °C
- 15 cm
- 16 cm
- 8.6 cm
- 2.07 kg
- Shipping Width
- 24 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 9.6 cm
- Shipping Weight
- 2.29 kg
