Level up your gaming experience with precision sound, adaptive ANC, innovative microphone with beamforming technology and long-lasting comfort.
Engineered for gaming. Designed for life.
Beoplay Portal are powerful, comfortable headphones designed to fit harmoniously into your life – whether gaming, listening to music, or on calls. Wirelessly connect to your PC to chat, interact and listen to music during office hours, answer calls on your phone, then jump into a full-on gaming experience with seamless Xbox connectivity when it's time to relax.
ADVANCED MICROPHONE TECHNOLOGY
Vocal communication
Communicate clearly with our innovative virtual boom arm. An array of microphones amplify your voice while filtering out background noise, allowing for complete freedom of movement and a high-quality speech performance. A quick access mute option makes it easy to switch between modes, so you're always in control.
BE IN THE MOMENT
Immersive sound
Beoplay Portal’s rich audio experience delivers all the detail and nuance that make your game come to life. In addition to expert tuning from Bang & Olufsen sound engineers, Beoplay Portal features Dolby Atmos for Headphones to create unparalleled immersion through spatial audio (for Xbox, Windows 10 and compatible mobile devices).
COMFORT IN MINIMALISM
Designed for extended wear and weighing only 282g, for a lightweight and comfortable fit. Memory foam, breathable materials and jaw-supporting ear cushions improves acoustic and comfort. The headband features innovative offset padding to relieve pressure.
DESIGNED FOR XBOX LIMITED SERIES X|S
Instant connection
Designed in collaboration with XBOX as part of the unique Limited Series X|S accessories range, Beoplay Portal will connect seamlessly with your XBOX for an instant gaming experience. Built-in lossless 2.4GHz wireless connectivity delivers a rock-solid connection, allowing full gaming immersion with precise and powerful Bang & Olufsen sound.
VIRTUAL SURROUND SOUND
Be immersed
The expertise of our world-class engineers combined with advanced Dolby Atmos enabled surround sound means that Beoplay Portal offer an unparalleled gaming experience: precise, immersive sound that puts you right in the heart of the action.
USER INTERFACE
Adjust your experience
Intuitive touch controls provide frictionless access to features such as mute, volume, ANC and Own Voice technology. Whether making a change mid-game or pausing your working day to pick up a call, the interface makes it easy.
CONNECTIVITY
Stay connected
However you game, Beoplay Portal are ready to connect. Our multi-platform headphones feature both Xbox Wireless and Bluetooth 5.1 to enable a seamless, low latency performance on Xbox, PC and mobile devices. If you prefer to cord up, USB-C is also an option.
Engineered for gaming, designed for life
Beoplay Portal are powerful, comfortable headphones designed to fit harmoniously into your life - whether gaming, listening to music, or on calls. Wirelessly connect to your PC to chat, interact and listen to music during office hours, answer calls on your phone, then jump into a full-on gaming experience with seamless Xbox connectivity when it's time to relax. -
Vocal communication
Communicate clearly with the innovative virtual boom arm. An array of microphones amplify your voice while filtering out background noise, allowing for complete freedom of movement and a high-quality speech performance. A quick access mute option makes it easy to switch between modes, so you're always in control. -
Immersive sound
Beoplay Portal's rich audio experience delivers all the detail and nuance that make your game come to life. In addition to expert tuning from Bang & Olufsen sound engineers, Beoplay Portal features Dolby Atmos for Headphones to create unparalleled immersion through spatial audio. -
Comfort in minimalism
Designed for extended wear and weighing only 282g, for a lightweight and comfortable fit. Memory foam, breathable materials and jaw-supporting ear cushions improves acoustic and comfort. The headband features innovative offset padding to relieve pressure. -
Power up
With up to 12 hours of wireless performance, Beoplay Portal gaming headphones offer extended hours of full immersion. Utilizing Bluetooth only, the battery life lasts up to 24 hours with ANC on. -
Play it your way
Connect and charge via a USB-C cable to utilize Dolby Atmos while connected. Beoplay Portal also come with a standard 3.5mm jack for wired playback. An optional PC dongle offers an easy way to wirelessly pair with your home computer set up. -
Comfortable and durable
Beoplay Portal headphones are crafted from premium, lightweight and strong materials: finely milled aluminum, soft and durable lambskin on the earcups, composite polymer that lasts forever, and knitted bamboo fiber textile for breathability and comfort.
- Bang & Olufsen Beoplay Portal - headphones with mic
- Product Type
- Headphones - Bluetooth / 2.4 GHz radio frequency - wireless, wired - 3.5 mm jack, USB-C
- Recommended Use
- Game console, portable electronics, computer
- Additional Functions
- Transparency mode
- Style
- Games
- Antracite black
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 22000 Hz - Sensitivity 95 dB/mW
- Impedance
- 24 Ohm
- Active Noise Canceling
- Controls
- Power on/off, volume control, microphone on/mute, play/pause, ANC/transparency
- 3-year warranty
- Product Type
- Transparency mode
- Style
- Games
- 16.73 cm
- 9.26 cm
- 17.87 cm
- 282 g
- Antracite black
- Body Material
- Aluminium, rubber, composite polymer, bamboo fibre cloth
- Earpad Material
- Memory foam, lambskin
- Recommended Use
- Max Operating Distance
- 12 m
Audio Output
- Full size
- Dynamic
- Wireless, wired
- Bluetooth Audio Codec
- SBC, AAC, aptX
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Stereo
- Built-in Decoders
- Dolby Atmos
- Active Noise Cancelling Technology
- Adaptive Noise Cancellation
- 20 - 22000 Hz
- Sensitivity
- 95 dB/mW
- Impedance
- 24 Ohm
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium
- Google Fast Pair, Microsoft Swift Pair
Microphone
- Form Factor
- Built-in
Remote Control
- Controls
- Connector Type
- Headphones (mini-phone 3.5mm) , USB (24 pin USB-C)
Cable
- Cable Length
- 1.25 m
- Included Accessories
- Inflight adapter
- Cable Details
- USB-C to USB-A cable - detachable - 1.25 m , Headphones cable - detachable - 1.25 m
- MFI
- Battery
- Headphone battery rechargeable - Lithium Ion
- Capacity
- 1200 mAh
- Run Time (Up To)
- 24 hour(s)
- Run Time Details
- Continuous playback (active noise-cancelling on) (2.4 GHz / Bluetooth): up to 12 hours , Continuous playback (active noise-cancelling on) (Bluetooth ON): up to 24 hours
- Recharge Time
- 3 hour(s)
- Limited warranty - 3 years
