Bang & Olufsen BeoPlay EQ - Black
Quicklinx: GJXCWS00 Mfr#: 1240000
Take a moment to center yourself when things at home get hectic. Adaptive active noise cancellation compensates for background noise while the snug, in-ear fit passively reduces disturbances too. Small and lightweight, Beoplay EQ in-ear headphones are comfortable enough to wear even when lying with your head on a pillow. Enjoy peace whenever you need it most or experience the true quality of your favorite albums without interruption.
  • Authentic audio
    Tuned by acclaimed sound engineers, true noise-canceling earphones delivering Bang & Olufsen Signature Sound. Enjoy powerful, authentic audio delivered by a 6.88 mm electro-dynamic new driver. The powerful audio performance is enhanced by a customizable fit for passive noise reduction.
  • Adaptive noise-canceling headphones
    Adaptive ANC and Acoustic technology create a stable performance for total silence, authentic audio and crystal clear calls without distraction. Compensating for a wide variety of background noises, Beoplay EQ offers true wireless immersion wherever you are.
  • Seamless connections
    For a true wireless listening experience, Beoplay EQ supports a variety of streaming options, including Bluetooth 5.2. The ultra-low-power performance and advanced technology ensures more stable connections for lower battery consumption, so you can stay in sync for longer.
  • Wireless charging
    An advanced battery offers up to 20 hours of playtime or 6.5 hours with ANC with a fast charge feature for an additional two hours of playtime with just a 20-minute charge.
  • High-quality materials
    Made from durable premium materials, including anodized aluminum and sweat-resistant textured housing. The compact, aluminum charging case features a rubber-coated base optimized for Qi-charging.
  • Elegantly ergonomic design
    Beoplay EQ is ergonomically shaped to fit comfortably. Interchangeable ear tips in a variety of sizes allow adjustment for a snug fit. The aluminum touch interface offers easy access to features.
  • Freedom to work anywhere
    Stay in touch with six microphones and market-leading directional beamform technology for crystal clear calls. Enjoy moving freely throughout your home while connected to important calls with hands free or take part in a video conference while staying aware of your surroundings with Transparency Mode. The long-lasting battery matches you step for step and when you need extra time, a brief 20-minute charge gives you two more hours of playtime.
Bang & Olufsen Beoplay EQ - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Portable electronics
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 107 dB
Impedance
17 Ohm
Active Noise Canceling
Microphone Operation Mode
Omni-directional
Microphones Included
6
True wireless earphones - Bluetooth - wireless
Dimensions & Weight Details
Charging case: 7.7 cm x 2.6 cm x 4 cm / 50 g , Earbud: 2.4 cm x 2.7 cm x 2.2 cm / 8 g
2.4 cm
2.7 cm
2.2 cm
8 g
Body Material
Aluminium, silicone, polymer
Recommended Use
Protection
Splashproof, dust-resistant, sweat-resistant, IP54
Audio Output
In-ear
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC, aptX
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Active Noise Cancelling Technology
Adaptive Noise Cancelling
Frequency Response
20 - 20000 Hz
Sensitivity
107 dB
Impedance
17 Ohm
Diaphragm
6.88 mm
Microphone
Built-in
Omni-directional
6
4 pairs of silicone ear tips (extra small, small, medium, large), Comply ear tips, charging case (340 mAh)
Cable Details
USB-C to USB-A cable - 50 cm
Headphone battery rechargeable
85 mAh
Run Time (Up To)
7.5 hour(s)
Run Time Details
Continuous playback (with included charging case): up to 20 hours , Continuous playback (noise cancelling ON): up to 6.5 hours , Continuous playback (noise cancelling OFF): up to 7.5 hours
Recharge Time
1.5 hour(s)
