Bang & Olufsen Beoplay E8 Sport - Black
Quicklinx: GJXBWS00 Mfr#: 1235400
Nothing moves you like music. The more intensely you experience your songs, the more motivated you feel. Bang & Olufsen's team of world-leading audio engineers has worked to ensure Beoplay E8 Sport delivers high-performance audio that helps you go further.
  • Bang & Olufsen signature sound
    Boost your workouts with Beoplay E8 Sport's powerful and precise sound that's expertly tuned for sport. Personalize your music experience using BeoSonic and activate Transparency Mode when you need to hear the world around you. Four built-in microphones ensure stellar clarity wherever you take your calls.
  • 30 hours of total playtime
    Beoplay E8 Sport delivers market-leading all-day battery performance for your training. A single charge gives you up to seven hours of non-stop music. And with an additional 3.5 charges from the compact carrying case, total playtime reaches up to 30 hours.
  • Secure and customizable fit
    Beoplay E8 Sport earphones fit securely in your ears so you can focus on your goal. Their durable, lightweight and ergonomically shaped earbuds come with a variety of silicone ear tips and soft fins that ensure an optimized fit. When it's time to clean the ear tips, simply take them off and rinse under running water.
  • Cordless convenience
    Beoplay E8 Sport's durable and compact charging case lets you charge on the go. If you forget to put your earbuds back in their case after your workout, a quick 20-minute charge will get you 90 minutes of playtime. The case is also Qi-enabled for seamless wireless charging from an optional charging pad.
  • Waterproof and sweat-resistant
    Use Beoplay E8 Sport in all weather conditions without compromising your sound experience. Built using superior materials, Beoplay E8 Sport wireless earphones are IP57 certified sweat-resistant and completely waterproof down to one meter for 30 minutes. And they're easy to clean after your workout.
  • Seamless wireless performance
    Experience superior sound, flawless connections, and crystal clear call clarity with Bluetooth 5.1 and Qualcomm aptX technologies. And with the earbud's innovative touch interface, you can keep your phone in your pocket and your eyes on your goal.
Bang & Olufsen Beoplay E8 Sport - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Portable electronics
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Stereo
Sound Effects
Signature Sound
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 107 dB
Impedance
16 Ohm
Noise Isolating
Microphone Operation Mode
Omni-directional
True wireless earphones - Bluetooth - wireless
Dimensions & Weight Details
Charging case: 7.06 cm x 3.56 cm x 3.35 cm / 55 g , Earbud: 2.3 cm x 2.1 cm x 2.5 cm / 6.4 g
Body Material
Aluminium, silicone, polymer
Recommended Use
Protection
IP57
Audio Output
In-ear
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC, aptX
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Stereo
Sound Effects
Signature Sound
Noise Isolating
Frequency Response
20 - 20000 Hz
Sensitivity
107 dB
Impedance
16 Ohm
Diaphragm
5.7 mm
Microphone
Built-in
Omni-directional
Pair of Comply foam ear tips, 4 pairs of silicone ear tips (extra small, small, medium, large), charging case (800 mAh), 3 pairs of silicone ear fins (small, medium, large)
Cable Details
USB charge cable - 1.25 m
IP57
2 x headphone battery rechargeable - wireless charging
Wireless Charging Standards
Qi
Included Qty
2
60 mAh
Run Time (Up To)
7 hour(s)
Run Time Details
Continuous playback (with included charging case): up to 30 hours
Recharge Time
2 hour(s)
