Ballistix Tactical 16GB (4GBx4) DDR4 3000 MT/s (PC4-24000) CL15 SR x8 Unbuffered DIMM 288pin
Quicklinx: C9RKWS00 Mfr#: BLT4C4G4D30AETA
If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
  • Put your game face on
  • Timing is everything
Ballistix Tactical - DDR4 - kit - 16 GB: 4 x 4 GB - DIMM 288-pin - 3000 MHz / PC4-24000 - unbuffered
Memory kit
16 GB: 4 x 4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz (PC4-24000)
Latency Timings
CL15 (15-16-16)
Black PCB, Intel Extreme Memory Profiles (XMP 2.0), gunmetal grey heat spreader, unbuffered
Voltage
1.35 V
Limited lifetime warranty (Germany - 10 years)
16 GB: 4 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15 (15-16-16)
Non-ECC
Module Configuration
512 x 64
Voltage
1.35 V
Colour Category
Grey
