Ballistix Sport 4GB DDR4 2400 MT/s (PC4-19200) CL16 SR x8 Unbuffered SODIMM 260pin
Quicklinx: C9T0WS00 Mfr#: BLS4G4S240FSD
Designed for performance enthusiasts and anyone who simply wants to get more out of their system, Crucial Ballistix Sport performance memory helps you do just that. Give your processor the resources it needs to perform and make your computer faster and more responsive.
  • Make your system go faster
    Memory is fun when it's faster, when it's stylish, and when it helps your system perform at a higher level. Compared to standard PC memory, that's exactly what Ballistix Sport is engineered to do. Get faster speeds and run demanding applications with ease. Multitask at will with increased bandwidth. And strike first with better latencies and reduced load times.
  • Install with ease
    Getting more out of your system should be easy - and that's exactly how Ballistix Sport memory is engineered. Using the advanced technology, intuitive module design, and more, Ballistix Sport is designed with the sole intent of creating affordable, easy-to-use performance memory. Installation is a cinch: just plug-and-play, and get ready to win with little to no BIOS configuration.
Ballistix Sport LT - DDR4 - module - 4 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
4 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL16 (16-16-16)
Heat sink, Black PCB, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
4 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL16 (16-16-16)
Non-ECC
Voltage
1.2 V
Colour Category
Grey
