Ballistix Elite 8GB (2x4GB) DDR3-1866 1.5V UDIMM Memory
Quicklinx: 901DWS00 Mfr#: BLE2CP4G3D1869DE1TX0CEU
Simply the best.
  • Advanced finned Integrated heat spreader
  • Black PCB
  • Advanced speeds and timings
  • Thermal sensor allows real-time temperature monitoring
  • Custom Ballistix M.O.D. Utility - temperature monitor and history
  • Premium-quality DRAM
  • Limited Lifetime Warranty
  • Proven stability and reliability
  • Crucial: a trusted name in memory
Elite force.
The Crucial BallistixElite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, our Ballistix Elite modules feature the best technical features available in an eye-catching design.
Latest and greatest.
Designed for unprecedented gaming performance, we’ve engineered the Crucial Ballistix Elite series to include an enhanced mechanical heat spreader design, a sleek black PCB, and integrated thermal sensors. That makes it the ideal choice for top-notch performance: enjoy the fastest speeds and best response times, along with the stability and quality you’ve come to expect from the Crucial name. Available in DDR3 for the latest cutting-edge platforms.
Guaranteed Compatible
Crucial Ballistix Elite Series memory is backed by our outstanding service and support, enjoys a limited lifetime warranty, and is guaranteed compatible.
  • Elite force
    The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design.
  • Greatest
    Designed for unprecedented gaming performance, the Crucial Ballistix Elite series includes an enhanced mechanical heat spreader design, a sleek PCB, and integrated thermal sensors. That makes it the ideal choice for top-notch performance: enjoy the fastest speeds and best response times.
Ballistix Elite - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL9 (9-9-9-27)
Heat sink, unbuffered
Voltage
1.5 V
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-27)
Non-ECC
Module Configuration
512 x 64
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
