Ballistix Elite 16GB (4GBx4) DDR4 3200 MT/s (PC4-25600) CL16 SR x8 Unbuffered DIMM 288pin
Quicklinx: C9QPWS00 Mfr#: BLE4C4G4D32AEEA
The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design.
  • Elite force
  • Greatest
    Designed for unprecedented gaming performance, the Crucial Ballistix Elite series includes an enhanced mechanical heat spreader design, a sleek PCB, and integrated thermal sensors. That makes it the ideal choice for top-notch performance: enjoy the fastest speeds and best response times.
Ballistix Elite - DDR4 - kit - 16 GB: 4 x 4 GB - DIMM 288-pin - 3200 MHz / PC4-25600 - unbuffered
Memory kit
16 GB: 4 x 4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3200 MHz (PC4-25600)
Latency Timings
CL16 (16-16-16)
Temperature monitoring, black heatsink, dual channel, Black PCB, quad channel, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.35 V
Limited lifetime warranty (Germany - 10 years)
16 GB: 4 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 (16-16-16)
Non-ECC
Module Configuration
512 x 64
Voltage
1.35 V
Colour Category
