Ballistix Elite 16GB (4GBx4) DDR3 2133 MT/s (PC3-17000) CL11 @1.65V UDIMM w/XMP/TS 240pin
Quicklinx: C9V1WS00 Mfr#: BLE4C4G3D21BCE1J
The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design.
  • Elite force
  • Greatest
    Designed for unprecedented gaming performance, the Crucial Ballistix Elite series includes an enhanced mechanical heat spreader design, a sleek PCB, and integrated thermal sensors. That makes it the ideal choice for top-notch performance: enjoy the fastest speeds and best response times.
Ballistix Elite - DDR3 - kit - 16 GB: 4 x 4 GB - DIMM 240-pin - 2133 MHz / PC3-17000 - unbuffered
Memory kit
16 GB: 4 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC3-17000)
Latency Timings
CL11 (11-11-11-27)
Temperature monitoring, Intel Extreme Memory Profiles (XMP), Advanced finned Integrated heatspreader, Black PCB, unbuffered
Voltage
1.65 V
Limited lifetime warranty (Germany - 10 years)
16 GB: 4 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11 (11-11-11-27)
Non-ECC
Module Configuration
512 x 64
Voltage
1.65 V
Colour Category
