The Crucial Ballistix Sport Series is designed for mainstream users and general enthusiasts. A simple, slick heat spreader delivers thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility. With industry-standard specifications, little or no BIOS configuration is required. That means this product installs easily, so you can get up and going / gaming quickly. Available in both DDR2 and DDR3 in the most common and popular speeds and densities, you'll be sure to find a product that suits your needs.
- Ballistix Sport - DDR2 - module - 2 GB - DIMM 240-pin - 800 MHz / PC2-6400 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 800 MHz (PC2-6400)
- Latency Timings
- CL5
- Aluminium heat spreader, unbuffered
- Voltage
- 1.8 V
- Limited lifetime warranty
- Capacity
- 2 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL5
- Non-ECC
- Module Configuration
- 256 x 64
- Voltage
- 1.8 V
- Compatible Slots
- 1 x memory - DIMM 240-pin
