The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design.
Elite force
The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design. -
Greatest
Designed for unprecedented gaming performance, the Crucial Ballistix Elite series includes an enhanced mechanical heat spreader design, a sleek PCB, and integrated thermal sensors. That makes it the ideal choice for top-notch performance: enjoy the fastest speeds and best response times.
- Ballistix Elite - DDR3 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 2133 MHz / PC3-17000 - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC3-17000)
- Latency Timings
- CL11 (11-11-11-27)
- Temperature monitoring, Advanced finned Integrated heatspreader, Black PCB, unbuffered
- Voltage
- 1.65 V
- Limited lifetime warranty (Germany - 10 years)
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- Non-ECC
- Module Configuration
- 1024 x 64
- Voltage
- 1.65 V
- Colour Category
- Black
