B-Tech Ventry Universal Soundbar Mount
Quicklinx: CLLMWS00 Mfr#: BTV914/B
Hurry, only 1 left in stock!
£30.95 ex VAT
£37.14 inc VAT
  • Ideal solution for mounting a Soundbar Speaker to your Flat Screen TV
  • Mounts Soundbar above or below the screen
  • Universal mount suitable for most soundbars and flat screens
  • Use with or without a flat screen wall mount
  • Ideal for corner installations with an articulated mount
  • Low profile steel brackets
  • Max weight of Soundbar: 10kg (22lbs)
  • Easy installation - All mounting hardware included
  • Compatible with SONOSĀ® Playbar
  • Versatile placement
    Designed for flexibility, this mounting kit allows for speakers to be placed either above or below the screen, catering to different room layouts and user preferences for an optimized audio experience.
  • Durable construction
    Crafted from steel, the B-TECH Ventry Universal mounting kit ensures durability and reliability, securing your speakers with a material built to last.
B-TECH Ventry Universal BTV914 mounting kit - for speaker(s) - black
Mounting kit - above the screen, below the screen
Mounting Components
2 brackets
20.28 cm x 0.25 cm x 49.71 cm
Recommended Use
Speaker(s)
Max Load Weight
10 kg
Material
Steel
20.28 cm
0.25 cm
49.71 cm
Material
Steel
AV Furniture
Mounting kit
Mounting Components
2 brackets
Recommended Use
Speaker(s)
Placing / Mounting
Above the screen, below the screen
Max Load Weight
10 kg
Brand: B-Tech
