- Adjustable adaptor for attaching 50mm poles to truss systems, scaffolding and other horizontal poles;
- Cable management;
- Supplied with safety bolt for secure installation;
- Fits truss size from 42mm (1.7") – 50mm (2");
- Zinc plated clamp;
- POLE SOLD SEPARATELY.
Robust design
Designed to support devices up to 140 kg, this mounting component ensures a secure and stable setup for your AV equipment. -
Versatile compatibility
The B-TECH System 2 BT7825 is engineered to accommodate a wide range of AV furniture, making it a practical choice for various setups and configurations.
- B-TECH System 2 BT7825 mounting component - black
- Product Type
- Mounting component
- Mounting Components
- Truss clamp
- Max Load Weight
- 140 kg
- Black
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Black
AV Furniture
- Truss clamp
- Cable Management
- Cable Management System (CMS)
- Max Load Weight
- 140 kg
