Effortless assembly
The B-TECH System X stand is designed for easy setup, ensuring a quick and hassle-free assembly process for your 2x2 video wall. -
Versatile display compatibility
Accommodating a wide range of display sizes from 46" to 60", this stand supports flat panel mount interfaces from 200 x 200 mm up to 600 x 400 mm, making it a flexible solution for various video wall configurations. -
Integrated cable management
With integrated cable management, the B-TECH System X keeps cables neatly organized and out of sight, promoting a clean and professional setup.
- B-TECH System X BT8370-2X2/BS stand - for 2x2 video wall - black, silver
- Product Type
- Stand
- 200.5 cm x 95 cm
- Adjustable Height
- 189.8- 209.4 cm
- Recommended Use
- 2x2 video wall
- Recommended Display Size
- 46"-60"
- VESA Mounting Interface
- 200 x 200 mm, up to 600 x 400 mm
- Max Load Weight
- 50 kg
- Black, silver
- 200.5 cm
- 95 cm
- Adjustable Height
- 189.8- 209.4 cm
- Black, silver
AV Furniture
- Stand
- Recommended Use
- 2x2 video wall
- Cable Management
- Integrated cable management
- 46"-60"
- Max Load Weight
- 50 kg
