B-Tech Projector ceiling mount for LCD/LED/DLP projectors tilt and
Quicklinx: 7YQKWS00 Mfr#: BT5890-010W
Marketing description is not available.
B-TECH System V BT5890-010 - mounting kit - for projector - white
Mounting kit - ceiling mountable
Mounting Components
Ceiling mount, ceiling plate
Adjustments
Tilt
Recommended Use
Projector
Max Mounting Pattern Size
493 x 493 mm
Max Load Weight
10 kg
White
White
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
493 x 493 mm
Cable Management
Integrated cable management
Adjustments
Tilt
Max Load Weight
10 kg
Rotating, swivel adjustment
