B-Tech LCD TFT Desk mount tilt swivel single arm full motion
Quicklinx: 7RGPWS00 Mfr#: BT7382/GB
  • Designed for screens up to 24" (61cm) / 9kg (20lbs)
  • Fits screens with VESA mounting patterns: 75 x 75mm and 100 x 100mm
  • Supplied with both a desk clamp and grommet
  • Maximum extension: 390mm
  • Easy tilt adjustment: +/-40°
  • Features two swivel points: 360° at pole and 180° at interface
  • Easy height adjustment using tool-less locking ring
  • Simple installation with all fixings included
  • Available in stylish Graphite Black finish
  • Minimum recommended screen weight: 1.5kg (3.3lbs)
Maximum Screen Size
24” (61cm)
Maximum Weight
9kg (20lbs)
Tilt
+/-40°
Swivel
VESA Compatibility
75 x 75, 100 x 100
Maximum Extension
390mm
