- B-TECH BT8505 cart - for flat panel - graphite black
- Product Type
- Cart
- 100 cm x 50 cm x 191 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 30"-50"
- VESA Mounting Interface
- 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 300 x 300 mm
- Max Load Weight
- 70 kg
- Graphite black
- 100 cm
- 50 cm
- 191 cm
- Graphite black
AV Furniture
- Cart
- Recommended Use
- Flat panel
- Cable Management
- Integrated cable management
- 30"-50"
- Max Load Weight
- 70 kg
- Wheels
