Versatile mounting options
The B-TECH System 2 BT7017 offers a range of mounting components, including an I-beam clamp and a tube mount adapter, providing flexibility for various installation environments. -
Adjustable and secure
Featuring adjustable width and a lockable mechanism, this mounting component ensures a perfect fit and added security for your AV equipment, supporting up to 140 kg with ease.
- B-TECH System 2 BT7017 mounting component - black
- Product Type
- Mounting component
- Mounting Components
- I-beam clamp, tube mount adapter
- Adjustable Width
- 8-25 cm
- Adjustments
- Tilt
- Max Load Weight
- 140 kg
- Black
- Designed For
- System 2 BT7850-025, BT7850-05, BT7850-10, BT7850-15, BT7850-20
- Adjustable Width
- 8-25 cm
- Black
AV Furniture
- Cable Management
- Cable Management System (CMS)
- Adjustments
- Tilt
- Max Load Weight
- 140 kg
- Adjustable width, lockable
- Designed For
- B-TECH System 2 BT7850-025, BT7850-05, BT7850-10, BT7850-15, BT7850-20
