Designed for flat screens up to 65" (165cm) / 70kg (154lbs)
Suitable for screens with VESA and non-VESA fixings with universal screen mounting kit including M4, M5, M6 and M8 screws
Maximum distance between mounting holes: Horizontal: 825mm (32.5") / Vertical: 500mm (19.7")
Compatible with VESA mounting patterns: 75mm x 75mm, 100mm x 100mm, 200mm x 100mm, 200mm x 200mm, 300mm x 200mm, 400mm x 400mm, 600mm x 400mm, 800mm x 400mm
Low profile design mounts screen only 30mm (1.2") from wall
Locking bar included for secure installation
Suitable for concrete / brick or up to 32" stud walls
Simple `hook-on' installation with all mounting hardware included
Can be fitted to System 2 installations using BT8435 collars
