B-Tech Hook on Plasma Mount Max Tilt 65" - black
Quicklinx: 7RGHWS00 Mfr#: BTEBT8432B
Type: Mounting kit
£69.24 ex VAT
£83.08 inc VAT
  • Designed for flat screens up to 65" (165cm) / 70kg (154lbs)
  • Suitable for screens with VESA and non-VESA fixings with universal screen mounting kit including M4, M5, M6 and M8 screws
  • Maximum distance between mounting holes: Horizontal: 825mm (32.5") / Vertical: 500mm (19.7")
  • Compatible with VESA mounting patterns: 75mm x 75mm, 100mm x 100mm, 200mm x 100mm, 200mm x 200mm, 300mm x 200mm, 400mm x 400mm, 600mm x 400mm, 800mm x 400mm
  • Low profile design mounts screen only 30mm (1.2") from wall
  • Locking bar included for secure installation
  • Suitable for concrete / brick or up to 32" stud walls
  • Simple `hook-on' installation with all mounting hardware included
  • Can be fitted to System 2 installations using BT8435 collars
Screen Size
up to 65”
Max. Weight
70kg (154lbs)
Dist from Wall
30mm (1.2”)
Max Dist between Fixings
H: 825mm (32.5”) V: 500mm (19.7”)
VESA Compatibility
75 x 75, 100 x 100, 200 x 100, 200 x 200, 300 x 200,300 x 300, 400 x 400, 600 x 400, 800 x 400
Maximum Screen Size
65"
Type: Mounting kit
Brand: B-Tech
