B-Tech Hook on Plasma Mount Max Flush 65" - black
Quicklinx: 7RGCWS00 Mfr#: BT8220/B
Type: Mounting kit
£38.82 ex VAT
£46.58 inc VAT
  • Designed for LED, LCD and Plasma screens up to 65" (165cm) / 70kg (154lbs)
  • Fits screens with mounting patterns up to H: 840mm (33.2") x V: 500mm (19.7") including VESA®: 75 x 75mm, 100 x 100mm, 200 x 100mm, 200 x 200mm, 300 x 200mm, 300 x 300mm, 400 x 200mm, 400 x 300mm, 400 x 400mm, 600 x 400mm and 800 x 400mm
  • Ultra-slim design mounts screen only 14mm (0.6") from wall
  • Features `OWLS'™ On Wall Levelling System
  • Suitable for concrete / brick or up to 32" stud walls
  • Security locking screws, Allen key and locking bar provided for secure installation
  • Universal screen fixing kit supplied, including M4, M5, M6, M8 screws and spacers
  • Simple `hook-on' installation with all mounting hardware included
  • Versatile compatibility
    Designed to support a wide range of flat panel sizes, this ultra-slim wall mount is compatible with flat panel mount interfaces from 75 x 75 mm up to 800 x 400 mm, ensuring a perfect fit for your display.
  • Robust design
    Capable of supporting flat panels weighing up to 70 kg, this wall mount combines strength with a sleek, ultra-slim profile, making it ideal for both home and professional settings.
  • Easy installation
    The BT8220 Universal Flat Screen Wall Mount is designed for a straightforward, hassle-free installation process, allowing for a secure wall mounting of your flat panel without the need for professional help.
Screen Size
up to 65”
Dist from Wall
14mm (0.6”)
VESA Compatibility
75 x 75, 100 x 100, 200 x 100, 200 x 200, 200 x 300, 300 x 200,300 x 300, 400 x 200, 400 x 300, 400 x 400, 600 x 400, 800 x 400
Maximum Weight
70Kg
Maximum Screen Size
65"
Type: Mounting kit
Brand: B-Tech
