B-Tech Hook on Plasma Mount Flush Max 45" - Black
Quicklinx: 7RG9WS00 Mfr#: BTEBT8200B
Type: Wall Mount
£27.08 ex VAT
£32.49 inc VAT
  • Designed for LED, LCD and Plasma screens up to 45" (114cm) / 35kg (77lbs)
  • Fits screens with mounting patterns up to 240mm (9.6") x 200mm (7.9") including VESA: 75mm x 75mm, 100mm x 100mm, 200mm x 100mm and 200mm x 200mm
  • Ultra-slim design mounts screen only 14mm (0.6") from wall
  • Features `OWLS'™ On Wall Levelling System
  • Features unique `Torsion Lock'™ security
  • Suitable for concrete or brick walls
  • Security locking screws, Allen key and locking bar provided for secure installation
  • Universal screen fixing kit supplied, including M4, M5, M6, M8 screws and spacers
  • Simple `hook-on' installation with all mounting hardware included
Screen Size
up to 45”
Dist from Wall
14mm (0.6”)
VESA Compatibility
75 x 75, 100 x 100, 200 x 100, 200 x 200
Maximum Weight
35Kg
Maximum Screen Size
45"
Type: Wall Mount
Brand: B-Tech
