- B-TECH Universal BT8422-PRO mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 3 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- Up to 80"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 800 x 500 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 200 mm, 200 x 100 mm
- Max Mounting Pattern Size
- 825 x 500 mm
- Max Load Weight
- 70 kg
- Black
- 3 cm
- Black
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 825 x 500 mm
- Up to 80"
- Max Load Weight
- 70 kg
- Lockable, low profile, hook-on installation
B-Tech Hook on Plasma Mount 860mm - Black
