Versatile compatibility
Designed to support flat panels ranging from 23" to 55", this ultraslim universal wall mount is perfect for a wide array of display sizes, ensuring a perfect fit for your screen. -
Advanced mounting technology
Featuring the innovative On Wall Levelling System (OWLS) and Torsion Lock, this mounting kit provides a secure, level, and easy installation process, ensuring your flat panel is perfectly positioned. -
Comprehensive flat panel interface support
With a broad range of flat panel mount interfaces from 75 x 75 mm up to 400 x 400 mm, this wall mount accommodates nearly any panel type, making it a versatile choice for your mounting needs. -
Robust construction
Capable of supporting flat panels up to 50 kg, this wall mount combines durability with a sleek design, offering a reliable solution without compromising on aesthetics.
- B-TECH BT8210 Ultra-Slim Universal Flat Screen Wall Mount mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- Recommended Use
- Flat panel
- Recommended Display Size
- 23"-55"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 200 x 100 mm, 300 x 300 mm, 200 x 300 mm
- Max Load Weight
- 50 kg
- Black
- Black
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 23"-55"
- Max Load Weight
- 50 kg
- Torsion Lock, On Wall Levelling System (OWLS)
