B-Tech Generic Large Flat Screen Display Trolley Kit
Quicklinx: 83DTWS00 Mfr#: BT8504B
Heavy Duty Plasma/LCD Trolley
B-Tech’s Heavy Duty Universal Flat Screen Wall Mounts are available with tilt and non-tilt (flush to the wall) options allowing for installation in most locations. They are designed for Plasma screens with a screen size from 32" to 65" and are GS/TUV approved for screens with a weight up to 150lbs) (70Kg). All heavy duty mounts come supplied with unique ‘Anti-Theft’ locking screws.
Great For Commercial Use
These mounts allow for screens to be displayed in either landscape or portrait style, without the need to change the position of the wall bracket. All wall brackets have cable management holes designed and shaped into the plate for stud wall mounting. The Universal Interface Bracket is compatible with over 95% of the screens available on the market, including all major brands. This industry grade plasma trolley is typically used in industrial or commercial settings and is most often purchased for tradeshows, office presentations or education facilities.
