B-Tech Flat screen wall mount with tilt 15"- 32"
Quicklinx: 8GP3WS00 Mfr#: BT7522/B
The BT7522 is designed for LCD VESA standard screens with a screen size up to 32", and weight up to 24Kg. The BT7522 has a tilt range of 30ยบ and mounts the screen only 55mm from the wall. A simple two piece installation process is all it takes to mount your screen to the wall.
Unique security screws, together with long hex key, are provided as standard to lock the screen to the bracket and help prevent theft. This bracket can be mounted on single wood studs or concrete/brick walls.
B-TECH BT7522 - mounting kit - for LCD display - black
Mounting kit - wall-mountable
Mounting Components
Tilt wall mount
Adjustments
Tilt
Recommended Use
LCD display
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 100 mm
Max Load Weight
24 kg
AV Furniture
Mounting kit
Mounting Components
Tilt wall mount
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
Adjustments
Tilt
Max Load Weight
24 kg
Security screws
