B-Tech Fixed Ceiling Mount for 50mm Poles - Black
Quicklinx: 7K8NWS00 Mfr#: BT7822/B
Accessory Type: Mount
More than 50 In Stock
£32.89 ex VAT
£39.46 inc VAT
Marketing description is not available.
  • Robust design
    Designed to support devices up to 90 kg, this mounting component ensures a secure and stable setup for your valuable equipment.
  • Versatile compatibility
    The B-TECH System 2 BT7822 is engineered for seamless integration with a wide range of devices, offering flexibility in setup configurations.
B-TECH System 2 BT7822 mounting component - black
Mounting component
Mounting Components
Ceiling plate, ceiling plate cover
15 cm x 15 cm x 12 cm
Max Load Weight
90 kg
15 cm
15 cm
12 cm
AV Furniture
Mounting component
Mounting Components
Cable Management
Integrated cable management
Max Load Weight
90 kg
Brand: B-Tech
