B-Tech Double Vesa LCD Ball Joint Mount- B
Quicklinx: 7RWDWS00 Mfr#: BT7515/PB
Type: Mounting kit
£78.61 ex VAT
£94.33 inc VAT
Marketing description is not available.
B-TECH BT 7515 mounting kit - for LCD display - silver
Mounting kit - wall-mountable
Mounting Components
Wall mount, dual arm
Adjustments
Tilt
Recommended Use
LCD display
Recommended Display Size
15"-42"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 100 x 200 mm
Max Load Weight
25 kg
Silver
Silver
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
15"-42"
Adjustments
Tilt
Max Load Weight
25 kg
Swivel base
Type: Mounting kit
Brand: B-Tech
