The BT8504 is a trolley designed specifically for displaying large flat panel displays. Suitable for plasma and LCD screens both VESA and non-VESA standard.
4 high qualities, non-marking braked castors are used to allow for easy transportation making this unit ideal for use in boardroom presentations, colleges and schools or for display purposes. Alternate leveling feet are provided as standard.
This system also allows the choice of whether to mount the screen in portrait or landscape styles.
Mounting options
The BT8504 features multiple flat panel mount interfaces including 75 x 75 mm, 100 x 100 mm, 200 x 100 mm, and 200 x 200 mm, allowing for a range of display compatibility. -
Construction
Engineered to support a maximum load of 70 kg, this cart ensures stability and strength, making it suitable for various display setups.
- B-TECH BT8504 cart - for flat panel - black base with chrome poles
- Product Type
- Cart
- 105 cm x 71.1 cm x 168 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 30"-50"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 200 x 100 mm, 300 x 300 mm, 200 x 300 mm
- Max Load Weight
- 70 kg
- Black base with chrome poles
- 105 cm
- 71.1 cm
- 168 cm
AV Furniture
- Cart
- Recommended Use
- Flat panel
- 30"-50"
- Max Load Weight
- 70 kg
- Braked wheels, cable access port
