B-TECH BT8431 - Mounting kit for LCD / plasma panel, screen size: 22" - 50"
Quicklinx: 74XKWS00 Mfr#: BT8431/B
Type: Mounting kit
More than 50 In Stock
£59.46 ex VAT
£71.35 inc VAT
Designed for screens up to 50" (127cm) / 35kg (77lbs)
Simple tilt adjustment +/-18°
Fits screens with VESA and non-VESA fixings with universal screen mounting kit including M4, M5, M6 and M8 screws
Maximum distance between mounting holes: Vertical: 400mm (15.7") / Horizontal: 465mm (18.3")
Compatible with VESA mounting patterns:
75mm x 75mm, 100mm x 100mm, 200mm x 100mm, 200mm x 200mm, 300mm x 200mm, 300mm x 300mm, 400mm x 200mm, 400mm x 300mm, 400mm x 400mm
Mounts screen only 80mm (3.1") from wall
Locking bar included for secure installation
Suitable for concrete / brick or up to 16" stud walls
Simple `hook-on' installation with all mounting hardware included
  • Versatile mounting options
    The B-TECH BT8431 offers a range of flat panel mount interfaces including 100 x 100 mm, 200 x 100 mm, and 200 x 200 mm, ensuring compatibility with a wide variety of flat panels. This flexibility allows for a seamless and secure installation in any setting.
  • Robust design
    Designed to support flat panels up to 35 kg, the B-TECH BT8431 tilt wall mount is built for durability and reliability. Its robust construction ensures your flat panel remains securely in place, providing peace of mind and a stable viewing experience.
B-TECH BT8431 mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Tilt wall mount
Recommended Use
Flat panel
Recommended Display Size
22"-50"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 200 x 100 mm, 300 x 300 mm
Max Load Weight
35 kg
AV Furniture
Mounting kit
Mounting Components
Tilt wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
22"-50"
Max Load Weight
35 kg
Type: Mounting kit
Brand: B-Tech
