- B-TECH BT7523 - mounting kit - for flat panel - piano black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Tilt wall mount
- Recommended Use
- Flat panel
- Recommended Display Size
- 15"-42"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 25 kg
- Piano black
- Designed For
- B-TECH BT7051, BT7052 50mm Accessory Collar, BT7260; System 2 BT7052
- Piano black
AV Furniture
- Mounting kit
- Tilt wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 15"-42"
- Max Load Weight
- 25 kg
- Designed For
- B-TECH BT7051, BT7052 50mm Accessory Collar, BT7260 , B-TECH System 2 BT7052
