B-TECH BT7523 - mounting kit - for flat panel - piano black
Quicklinx: 7WJDWS00 Mfr#: BT7523/PB
Type: Mounting kit
£23.00 ex VAT
£27.60 inc VAT
Marketing description is not available.
  • Versatile mounting options
    The B-TECH BT7523 mounting kit offers a range of flat panel mount interfaces including 100 x 100 mm, 200 x 100 mm, 200 x 200 mm, and 75 x 75 mm, ensuring compatibility with a wide variety of flat panel displays.
  • Robust design
    Designed to support flat panels weighing up to 25 kg, this tilt wall mount provides a secure and stable solution for displaying your flat panel on the wall.
B-TECH BT7523 mounting kit - for flat panel - piano black
Mounting kit - wall-mountable
Mounting Components
Tilt wall mount
Recommended Use
Flat panel
Recommended Display Size
15"-42"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
25 kg
Piano black
B-TECH BT7051, BT7052 50mm Accessory Collar, BT7260; System 2 BT7052
Piano black
AV Furniture
Mounting kit
Mounting Components
Tilt wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
15"-42"
Max Load Weight
25 kg
B-TECH BT7051, BT7052 50mm Accessory Collar, BT7260 , B-TECH System 2 BT7052
Type: Mounting kit
Brand: B-Tech
