AXIS T91A47 is specially suitable for small or large poles, up to 400 mm (15.7 in) in diameter. Additionally, it can be used for attaching cameras to beams. When AXIS T91A47 is used for a fixed dome camera, no additional accessories such as pendant kits are required, ensuring a cost efficient solution.
- AXIS T91A47 Pole Mount - camera mounting kit
- Product Type
- Camera mounting kit
- Placing / Mounting
- Pole mountable
- Indoor / Outdoor
- Indoor, outdoor
- 13.4 cm x 26.8 cm x 19.4 cm
- 300 g
- UL 60950-1, IEC 60950-1, EN 60950-1, IEC 62262 IK10, EN 50581, IEC 60950-22, EN 60950-22, UL 60950-22
- 3-year warranty
- Product Type
- Pole mountable
- Indoor / Outdoor
- Indoor, outdoor
- 13.4 cm
- 26.8 cm
- 19.4 cm
- 300 g
- Mounting Kit
- Included
- Pole strap, for pole with diameter 60 - 110 mm
- Limited warranty - 3 years
