AXIS T8516 PoE+ Network Switch is an easy-to-install network switch optimized for surveillance solutions, that comes with an unique web graphic user interface with topology for easy overview and management of all devices in the system.
Easy to install and configure
AXIS T8516 PoE+ Network Switch, just as Axis product portfolio, is easy to install by using standard Axis tools as AXIS IP utility and AXIS Camera Management. AXIS T8516 also comes with an individual password and easy to use setup wizard. AXIS T8516 comes with a comprehensive set of configuration tools such as an integrated DHCP server for automatic assignment of IP addresses. It also allows for even more advanced network configuration such as VLAN, QoS, Security, and Spanning tree to further optimize the total solution. -
Perfect match for Axis surveillance solutions
AXIS T8516 PoE+ Network Switch is made for the surveillance industry and a perfect complement to Axis recorders such as AXIS Camera Station S10 Series. This to simplify further setup and installation of the surveillance systems. -
Total overview with unique web graphic user interface
The unique web graphic user interface offers a graphic topology for easy overview of all devices in the system. The graphic user interface provides information, status and notifications about connected devices. It allows for management of all connected devices, reboot of cameras in the system, monitoring of network traffic, cable diagnostics and much more.
- Axis T8516 - switch - 16 ports - Managed - rack-mountable
- Switch - 16 ports - Managed
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 240 W
- Performance
- Throughput: 26.8 Mpps , Switching capacity: 36 Gbps
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- IGMP
- Remote Management Protocol
- SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH
- ARP support, VLAN support, IPv6 support, IP address filtering, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, DHCP server, IPv4 support, LLDP support, NTP server, 802.1x authentication, administrator's password, BPDU, ICMP, Private VLAN
- IEEE 802.3af, IEEE 802.1x, IEEE 802.1ab (LLDP), IEEE 802.3at, UPnP
- Power
- AC 120/230 V (50/60 Hz)
- 44.2 cm x 21.1 cm x 4.4 cm
- 3 kg
- Black
- 3-year warranty
- Designed For
- AXIS A1610-B, C1410, D3110, M3067-P, M3068-P, P1385-E, P1455-LE, P1455-LE-3 License Plate Verifier Kit, W400; Camera Station S1296
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 240 W
- Performance
- 8K entries
- 9216 bytes
- Routing Protocol
- IGMP
- Authentication Method
- Secure Shell (SSH)
- 18 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
- Power Device
- Internal power supply
- Power Provided
- 285 Watt
- Voltage Required
- Black
- Included Accessories
- 4 rubber feet, 2-port dust covers(SFP)
- Rack Mounting Kit
- Included
- SASO, EN55024, JATE, ICES-003 Class A, RoHS, KCC, WEEE, ANATEL, S Mark, REACH, FCC Part 15 B Class A, VCCI Class A, EAC, RCM, EN 55032 Class A, IEC/EN/UL 60950-1
- 44.2 cm
- 21.1 cm
- 4.4 cm
- 3 kg
- Limited warranty - 3 years
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 95% (non-condensing)
- Designed For
- AXIS A1610-B, C1410, D3110, M3067-P, M3068-P, P1385-E, P1455-LE, P1455-LE-3 License Plate Verifier Kit, W400 , AXIS Camera Station S1296
