Axis T8516 16 Port Network Switch
Quicklinx: D5KFWS00 Mfr#: 5801-693
Type: Gigabit Ethernet
Ports: 16
Managed: Yes
POE: PoE+
£606.19 ex VAT
£727.42 inc VAT
AXIS T8516 PoE+ Network Switch is an easy-to-install network switch optimized for surveillance solutions, that comes with an unique web graphic user interface with topology for easy overview and management of all devices in the system.
  • Easy to install and configure
    AXIS T8516 PoE+ Network Switch, just as Axis product portfolio, is easy to install by using standard Axis tools as AXIS IP utility and AXIS Camera Management. AXIS T8516 also comes with an individual password and easy to use setup wizard. AXIS T8516 comes with a comprehensive set of configuration tools such as an integrated DHCP server for automatic assignment of IP addresses. It also allows for even more advanced network configuration such as VLAN, QoS, Security, and Spanning tree to further optimize the total solution.
  • Perfect match for Axis surveillance solutions
    AXIS T8516 PoE+ Network Switch is made for the surveillance industry and a perfect complement to Axis recorders such as AXIS Camera Station S10 Series. This to simplify further setup and installation of the surveillance systems.
  • Total overview with unique web graphic user interface
    The unique web graphic user interface offers a graphic topology for easy overview of all devices in the system. The graphic user interface provides information, status and notifications about connected devices. It allows for management of all connected devices, reboot of cameras in the system, monitoring of network traffic, cable diagnostics and much more.
Axis T8516 - switch - 16 ports - Managed - rack-mountable
Switch - 16 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
240 W
Performance
Throughput: 26.8 Mpps , Switching capacity: 36 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMP
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH
ARP support, VLAN support, IPv6 support, IP address filtering, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, DHCP server, IPv4 support, LLDP support, NTP server, 802.1x authentication, administrator's password, BPDU, ICMP, Private VLAN
IEEE 802.3af, IEEE 802.1x, IEEE 802.1ab (LLDP), IEEE 802.3at, UPnP
44.2 cm x 21.1 cm x 4.4 cm
3 kg
3-year warranty
AXIS A1610-B, C1410, D3110, M3067-P, M3068-P, P1385-E, P1455-LE, P1455-LE-3 License Plate Verifier Kit, W400; Camera Station S1296
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
240 W
Performance
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMP
Authentication Method
Secure Shell (SSH)
18 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
Internal power supply
Power Provided
285 Watt
4 rubber feet, 2-port dust covers(SFP)
Rack Mounting Kit
Included
SASO, EN55024, JATE, ICES-003 Class A, RoHS, KCC, WEEE, ANATEL, S Mark, REACH, FCC Part 15 B Class A, VCCI Class A, EAC, RCM, EN 55032 Class A, IEC/EN/UL 60950-1
44.2 cm
21.1 cm
4.4 cm
3 kg
Limited warranty - 3 years
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
AXIS A1610-B, C1410, D3110, M3067-P, M3068-P, P1385-E, P1455-LE, P1455-LE-3 License Plate Verifier Kit, W400 , AXIS Camera Station S1296
Ports: 16
Managed: Yes
POE: PoE+
Brand: Axis
Price Range Ex VAT: £500 - £750
