Axis T8508 8 Port Network Switch
Quicklinx: D5KCWS00 Mfr#: 01191-003
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
POE: PoE+
Hurry, only 2 left in stock!
£377.11 ex VAT
£452.53 inc VAT
  • Robust performance
    With a throughput of 14.9 Mpps and a switching capacity of 20 Gbps, the Axis T8508 PoE+ Network Switch ensures efficient data flow and high-speed connectivity for demanding network environments.
  • Enhanced security
    The switch features advanced security protocols including 802.1x authentication, Access Control List (ACL) support, and HTTPS encryption, providing a secure network infrastructure to protect sensitive data.
  • Flexible connectivity
    Equipped with 8 PoE+ ports and 2 combo Gigabit SFP uplink ports, this switch offers versatile connection options for a wide range of devices, ensuring reliable power and data transmission.
  • Durable design
    Housed in a robust metal casing, the Axis T8508 is designed for durability. It operates efficiently across a wide temperature range, making it suitable for various operational environments.
  • Comprehensive network management
    This manageable switch supports numerous remote management protocols, including SNMP, HTTP, and SSH, allowing for easy configuration, monitoring, and maintenance of the network.
Axis T8508 PoE+ Network Switch - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP (uplink)
Power Over Ethernet (PoE)
PoE+
PoE Budget
130 W
Performance
Throughput: 14.9 Mpps , Switching capacity: 20 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMP
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, SMTP
DHCP support, ARP support, VLAN support, IPv6 support, IP address filtering, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, DHCP server, IPv4 support, fanless, LLDP support, NAC, 802.1x authentication, BPDU, ICMP, NTP, LLDP-MED, Private VLAN, HTTPS encryption, 6KV Surge protection, metal housing, administrator's password, UDP
IEEE 802.3af, IEEE 802.1x, IEEE 802.1ab (LLDP), IEEE 802.3at, UPnP
22 cm x 24.2 cm x 4.4 cm
2.1 kg
United Kingdom
3-year warranty
AXIS A1610-B, C1410, D3110, M3067-P, M3068-P, P1385-E, P1455-LE, P1455-LE-3 License Plate Verifier Kit, W400; Camera Station S1216 Recording Server, S1232, S1296
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
130 W
Performance
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMP
Authentication Method
Secure Shell (SSH)
8 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 1000Base-T RJ-45 uplink , 2 x 1000Base-X SFP uplink
4 rubber feet, drill template
SASO, EN55024, JATE, ICES-003 Class A, FCC Part 15 B Class A, VCCI Class A, EAC, AS/NZS CISPR 32 Class A, EN 55032 Class A, IEC/EN/UL 60950-1
United Kingdom
Software Included
Axis Camera Management
22 cm
24.2 cm
4.4 cm
2.1 kg
Limited warranty - 3 years
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
AXIS A1610-B, C1410, D3110, M3067-P, M3068-P, P1385-E, P1455-LE, P1455-LE-3 License Plate Verifier Kit, W400 , AXIS Camera Station S1216 Recording Server, S1232, S1296
Ports: 8
Managed: Yes
POE: PoE+
Brand: Axis
