AXIS T8120 Midspan 1-port Power Injector 15 Watt
Quicklinx: 9LY9WS00 Mfr#: 5026-202
Power over Ethernet (PoE) offers an easy, fast and cost-effective solution for supplying power to network video products without the need to install power outlets and electrical cabling.
With the use of Axis PoE products, Axis network cameras and video encoders can receive both data and power over a single Ethernet cable. Network video products can thus be installed in areas where traditional power cabling and outlets are unavailable or difficult to install.
  • Easier and faster installations
  • No need for power outlets
  • Axis PoE midspans and PoE splitters
    Axis PoE midspans provide power over Ethernet cables to network video products with built-in Power over Ethernet support. For network video products without built-in PoE support, a PoE splitter must be used to separate power and data coming over the network cable. Axis PoE midspans and PoE splitters are IEEE 802.3af compliant, which ensures compatibility with all Axis products that have built-in support for Power over Ethernet.
AXIS T8120 Midspan 15 W 1-port - PoE injector - 15 Watt
PoE injector - external
450 g
Europe
Input Voltage
AC 100-240 V
Output Voltage
48 V
Power Capacity
15 Watt
Output connectors
1 x RJ-45
6 cm x 14.5 cm x 3.1 cm
AXIS C1410, D3110, M1011 Network Camera, M1011-W Network Camera, M1013 Network Camera, M1014 Network Camera, M1031-W Network Camera, M1065-L, M3067-P, M3068-P, M4215-V, M4328-P, P1385-E, P1455-LE, P1455-LE-3 License Plate Verifier Kit, Q1656, Q1656-B, Q1951-E, W400; M42 Series; M55 Series
Europe
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
1 x RJ-45
Output Voltage
48 V
Power Capacity
15 Watt
1 x Gigabit LAN - RJ-45
UL, TUV, cUL, EN55022 Class B, FCC Part 15 B
10 - 90% (non-condensing)
6 cm
14.5 cm
3.1 cm
450 g
AXIS C1410, D3110, M1011 Network Camera, M1011-W Network Camera, M1013 Network Camera, M1014 Network Camera, M1031-W Network Camera, M1065-L, M3067-P, M3068-P, M4215-V, M4328-P, P1385-E, P1455-LE, P1455-LE-3 License Plate Verifier Kit, Q1656, Q1656-B, Q1951-E, W400 , AXIS M42 Series M4215-LV, M4218-LV , AXIS M55 Series M5526-E
