Axis Small-sized indoor network camera Fixed Lens 1/4"
Quicklinx: 6CD3WS00 Mfr#: 0301-003
AXIS M1011-W Network Camera is perfectly suited for securing small businesses, boutiques, restaurants, hotels or residences. The camera offers both wireless (IEEE 802.11g) and wired connection to the network for flexible installation. It offers superior video quality in its class at 30 frames per second in VGA resolution.
AXIS M1011-W provides multiple, individually configurable video streams in H.264 as well as motion JPEG and MPEG-4 Part 2. Full frame rate and resolution is provided in either compression. The H.264 compression enables optimization for bandwidth and storage efficiency by significantly reducing the bit rate.
  • Small and functional camera design
  • High-performance compression and streaming capabilities
AXIS M1011-W Network Camera - network surveillance camera
Network surveillance camera - fixed
5.9 cm x 3.4 cm x 9.5 cm
94 g
Wired, wireless
Camera
Max Resolution
640 x 480
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
1 lux F2.0
Focal Length
4.4 mm
Lens Iris
Fixed iris
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g
Voltage
DC 5 V
Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, brightness control, contrast control
Environmental Parameters (operating)
0 °C - 50 °C; 20 - 80% relative humidity
Wired, wireless
5.9 cm
3.4 cm
9.5 cm
94 g
United Kingdom
Camera
Colour - fixed
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
640 x 480
Exposure Range
1/5000 sec - 1/4 sec
1 lux F2.0
Video Capture
640 x 480 @ 30 fps , 160 x 120 @ 30 fps
RAM
64 MB
Flash Memory
32 MB
Image Sensor
CMOS 1/4"
Lens Construction
Focal Length
4.4 mm
Lens Iris
Fixed iris
Horizontal Field of View (degree)
47
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, HTTP over SSL, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, Bonjour, RTCP, IGMP
Interfaces Details
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, RSS-210, CCC, EN 60950-1, TELEC, EN 300 328, EN 301 489-1, EN 301 489-17
Power Requirements
DC 5 V
Power adapter - external
Software Included
Drivers & Utilities
50 °C
Relative Humidity (operating)
20 - 80%
