AXIS Q1765-LE network camera is a slim, bullet-style outdoor-ready network camera with 18x optical zoom and auto-focus. It delivers SMPTE-compliant HDTV 1080p video in multiple, individually configurable H.264 and motion JPEG video streams. The built-in IR illumination is provided by four, auto adjusting LEDs that are highly power-efficient. AXIS Q1765-LE can cover great distances providing both wide overviews as well as detailed images for identification purposes. In addition, Axis' unique Corridor Format allows effective monitoring with more resolution in vertical scenes such as long streets or long perimeters.
All features integrated in bullet-style
AXIS Q1765-LE network camera is a slim, bullet-style outdoor-ready network camera with 18x optical zoom and auto-focus. It delivers SMPTE-compliant HDTV 1080p video in multiple, individually configurable H.264 and motion JPEG video streams. The built-in IR illumination is provided by four, auto adjusting LEDs that are highly power-efficient. AXIS Q1765-LE can cover great distances providing both wide overviews as well as detailed images for identification purposes. In addition, Axis' unique Corridor Format allows effective monitoring with more resolution in vertical scenes such as long streets or long perimeters. -
Convenient installation
AXIS Q1765-LE is very convenient to install thanks to its light weight, one-cable installation, readily directed IR, support for standard Power over Ethernet and 24 V DC/AC input. The cameras mounting bracket is designed for installation on walls or ceiling of buildings for monitoring of entrances and perimeter. Together with compatible accessories, the AXIS-Q1765-LE can be mounted on poles for surveillance of parking lots or general city surveillance purposes.
- AXIS Q1765-LE Network Camera - network surveillance camera
- Network surveillance camera - fixed - outdoor
- Audio
- Yes: two-way audio capability
- Camera Mount Type
- Ceiling mount
- 14.6 cm x 21.9 cm x 10.5 cm
- 1.8 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 18 x
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/2.9"
- Minimum Illumination
- 0.5 lux - colour - F1.6 - 30 IRE , 0.04 lux - B&W - F1.6 - 30 IRE , 0 lux - IR
- Focal Length Control
- Vari-focal
- Focal Length
- 4.7 mm - 84.6 mm
- Focus Adjustment
- Automatic
- Lens Iris
- F/1.6-2.8
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 8 - 28 V / AC 20 - 24 V / PoE
- Backlight Compensation (BLC), manual exposure, sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, ONVIF support, infrared cut filter, Arctic Temperature Control, 3D Privacy Mask Function, OptimizedIR
- 3-year warranty
- Environmental Parameters (operating)
- -40 °C - 50 °C; 10 - 100% relative humidity
- Audio Support
- Camera Mount Type
- Ceiling mount
- Wired
- 14.6 cm
- 21.9 cm
- 10.5 cm
- 1.8 kg
Camera
- Colour - Day&Night - fixed - outdoor
- Digital Video Format
- MJPEG, H.264, AVC
- Max Digital Video Resolution
- 1920 x 1080
- Digital Zoom
- 12
- Exposure Range
- 2 sec - 1/28000 sec
- Digital Video Capture Resolution
- 1920 x 1080, 320 x 180
- Frame Rate (max)
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/2.9"
Lens Construction
- Vari-focal
- Optical Zoom
- 18 x
- Focal Length
- 4.7 mm - 84.6 mm
- Lens Iris
- F/1.6-2.8
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 4 - 59
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm , 1 x video - output
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, NEMA Type 4X, EN 61000-6-2, KCC Class A, IP66, EN 50121-4, VCCI Class A, KN24
- Power Requirements
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- -40 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 100%
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.92 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.60 |
