Your basket is empty
Axis Q1604
Axis Q1604
Quicklinx: 82CDWS00 Mfr#: 0439-001
  • SDHC Memory Card
£762.80 ex VAT
£915.36 inc VAT
The AXIS Q1604 Network Camera enables clear identification of both people and objects, even in highly variable lighting conditions. It is perfect for monitoring entrances and buildings with large windows such as airports and train stations.
The camera's Wide Dynamic Range with dynamic capture works by acquiring several images with different exposure times. The advanced image processing results in video with exceptional clarity and sharpness. AXIS Q1604 can handle complex scenes such as when light comes through a window creating both dark and bright zones. No part of the image turns out too dark or too bright.
The camera delivers progressive scan image quality at 1MP or HDTV 720p in compliance with the SMPTE standard in resolution. It can generate multiple, individually configurable H.264 and Motion JPEG video streams simultaneously.
AXIS Q1604 Network Camera - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: two-way audio capability, built-in microphone
7.8 cm x 15.1 cm x 4.6 cm
600 g
Wired
Camera
Colour - Day&Night
Max Resolution
1280 x 960
Frame Rate
30 frames per second
Video Modes
720p
Optical Sensor Type
CMOS - 1/3" - 1 MP
Minimum Illumination
0.1 lux - colour - F1.2 , 0.02 lux - B&W - F1.2
Focal Length Control
Vari-focal
Focal Length
2.8 mm - 8 mm
Lens Mounting
CS-mount
Lens Iris
F/1.2 (P-Iris)
Ethernet 10Base-T/100Base-TX
Voltage
DC 8 - 20 V / PoE
Backlight compensation, IR filter, sharpness control, white balance, colour control, brightness control, Power over Ethernet, contrast control, image mirror, Wide Dynamic Range (WDR), Open Network Video Interface Forum (ONVIF), Privacy Mask Function
3 years warranty
Environmental Parameters (operating)
0 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
Audio Support
Wired
7.8 cm
15.1 cm
4.6 cm
600 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 960
Video Modes
720p
RAM
256 MB
Flash Memory
128 MB
Image Sensor
1 MP CMOS 1/3"
Lens Construction
CS-mount - vari-focal
Focal Length
2.8 mm - 8 mm
Lens Iris
F/1.2 (P-Iris)
Horizontal Field of View (degree)
34 - 100
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, IGMP, QOS
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Stand
C-Tick, VCCI Class B ITE, IEC 61000-3-2, IEC 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, EN 61000-6-2, EN 60950-1
Power Requirements
DC 8 - 20 V / PoE
Software Included
Drivers & Utilities
Limited warranty - 3 years
50 °C
Relative Humidity (operating)
82CD C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.30
82CD C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.25
82CD C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.51
82CD C2G 2m Cat6a Shielded Patch - Blue In Stock £7.51
82CD C2G TruLink Media Gateway RJ45 Cap In Stock £0.58
82CD C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £47.56
Brand: Axis
Price Range Ex VAT: 750 - 1000
