Axis P5514-E PTZ Dome Network Camera
Quicklinx: BYW4WS00 Mfr#: 0755-001
  • SDHC Memory Card
  • 360° pan with Auto-flip
  • 12x optical zoom
  • HDTV 720p resolution
  • Outdoor-ready: IP66- and NEMA 4X-rated protection against dust, rain and snow
  • Easy installation including Power over Ethernet (IEEE 802.3af)
The outdoor-ready AXIS P5514-E PTZ Dome Network Camera is a compact and affordably priced day and night pan/tilt/zoom camera. It is suitable for surveillance applications in areas such as parking lots, construction sites and business premises.
Pan/tilt/zoom capabilities
The PTZ camera enables users at a remote location to pan 360° for overview surveillance, tilt 180° and zoom in 12x with autofocus for detailed views. The Advanced Gatekeeper functionality enables the camera to automatically move to a preset position when motion is detected in a pre-defined area.
High video quality
Thanks to the camera's day/night functionality, high image quality is maintained even in low-light conditions. AXIS P5514-E provides H.264 and Motion JPEG streams in up to 720p resolution at 25/30 fps frame rate. H.264 greatly optimizes bandwidth and storage without compromising image quality.
Easy and reliable installation
AXIS P5514-E supports standard Power over Ethernet for easy installation. The camera simply connects either to a PoE-enabled switch or via a PoE midspan to a switch with one network cable for carrying power, video/audio and PTZ controls.
The camera also has IP66 and NEMA 4X ratings, which ensure protection against dust, rain, snow, ice and corrosion. It can operate in temperatures from -20 °C to 50 °F (-4 °F to 122 °F).
AXIS P5514-E PTZ Dome Network Camera 50Hz - network surveillance camera
Network surveillance camera - pan / tilt / zoom - outdoor - dust / vandal / waterproof
Audio
Yes: two-way audio capability
Camera Mount Type
Wall mount, ceiling mount
1.3 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
12 x
Max Resolution
1280 x 720
Frame Rate (max)
60 frames per second
Motion Detection
Video Modes
720p
Optical Sensor Type
CMOS - 1/2.3"
Minimum Illumination
0.7 lux - colour - F1.4 - 30 IRE , 0.08 lux - B&W - F1.4 - 30 IRE
Focal Length
3.8 mm - 42.9 mm
Focus Adjustment
Automatic
Lens Iris
F/1.4-2.1 - auto iris
Panning Range (degree)
360
Tilting Range (degree)
180
Ethernet 10Base-T/100Base-TX
Voltage
DC 20 - 28 V / AC 20 - 24 V / PoE Plus
Backlight Compensation (BLC), sharpness control, white balance, brightness control, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, infrared cut filter, Video Motion Detection Technology, password protection, 100 preset positions, e-Flip, Audio Detection
3-year warranty
Environmental Parameters (operating)
0 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
Audio Support
Camera Mount Type
Wired
1.3 kg
Camera
Colour - Day&Night - pan / tilt / zoom - outdoor - dust / vandal / waterproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
Video Modes
720p
Digital Zoom
10
Exposure Range
1/25 sec - 1/8000 sec
Digital Video Capture Resolution
1280 x 720, 320 x 180
Frame Rate (max)
RAM
512 MB
Flash Memory
256 MB
Image Sensor
CMOS 1/2.3"
Lens Construction
Optical Zoom
12 x
Focal Length
3.8 mm - 42.9 mm
Lens Iris
F/1.4-2.1 auto iris
Focus Adjustment
Automatic
Horizontal Field of View (degree)
5.2 - 59.2
Panning
Range (degree)
360
Speed (degree/sec)
Up to 100
Tilting
Range (degree)
180
Speed (degree/sec)
Up to 100
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
Alarm Inputs Qty
1
Alarm Outputs Qty
1
Ports
LAN - RJ-45
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Sunshield, mounting kit, connector kit
C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, IEC 60529 IP66, EN 61000-6-1, FCC Part 15, ICES-003 Class A, NEMA Type 4X, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, VCCI Class A, KN24, KCC KN22, IEC 60950-22, AS/NZS CISPR22:2004 Class A, EN 60950-22, UL 60950-22, EN 55022 Class A
Power Requirements
12.95 Watt
Limited warranty - 3 years
50 °C
Relative Humidity (operating)
BYW4 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
BYW4 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.84
