The AXIS P3364-LV is a 1-megapixel day and night fixed dome network camera that offers superb video performance. AXIS P3364-LV features built-in IR illumination based on long-life LED technology that is highly power efficient. This results in high-quality, low-noise video also when the environment is completely dark. The built-in IR solution in AXIS P3364-LV automatically adapts the illumination angle with the zoom level, which simplifies installation.
High-performance with built-in IR
The AXIS P3364-LV is a 1-megapixel day and night fixed dome network camera that offers superb video performance. AXIS P3364-LV features built-in IR illumination based on long-life LED technology that is highly power efficient. This results in high-quality, low-noise video also when the environment is completely dark. The built-in IR solution in AXIS P3364-LV automatically adapts the illumination angle with the zoom level, which simplifies installation. -
Lightfinder technology and P-Iris control
AXIS P3364-LV integrates Axis' Lightfinder technology. The outstanding light sensitivity, with maintained colors even in very poor lighting conditions, is obtained by a combination of Axis' expertise in image processing, system-on-chip development and selection of the best optical components. The camera also supports P-Iris control, allowing the camera to precisely control the position of the iris. The iris opening is optimized for depth of field, lens resolution and light inlet, resulting in superb image quality with optimal sharpness. -
Vandal-resistant casing
AXIS P3364-LV with its vandal-resistant casing is a fixed dome specifically designed for indoor environments where discreet and compact solutions are required. It is the perfect solution for video surveillance in exposed areas such as airports, schools and prisons.
- AXIS P3364-LV 12mm - network surveillance camera - dome
- Network surveillance camera - fixed - dome - vandal-proof
- Audio
- Yes: two-way audio capability, built-in microphone
- 14.8 cm x 14.8 cm x 9.6 cm
- 670 g
- White
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 3.6 x
- Max Resolution
- 1280 x 960
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/3"
- Minimum Illumination
- 0.18 lux - colour - F1.4 , 0.04 lux - B&W - F1.4 , 0 lux - IR
- Focal Length Control
- Vari-focal
- Focal Length
- 3.3 mm - 12 mm
- Lens Iris
- F/1.4
- Panning Range (degree)
- 360
- Tilting Range (degree)
- 170
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE Plus
- Backlight Compensation (BLC), manual exposure, sharpness control, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, image mirror, Wide Dynamic Range (WDR), ONVIF support, infrared cut filter, built-in IR illuminator, Privacy Mask Function, P-Iris control, text stamp, Video Motion Detection Technology, tamper-detection, Lightfinder technology
- 3-year warranty
- Environmental Parameters (operating)
- 0 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
- Audio Support
- Form Factor
- Dome
- Wired
- 14.8 cm
- 14.8 cm
- 9.6 cm
- 670 g
Camera
- Colour - Day&Night - fixed - vandal-proof
- Digital Video Format
- MJPEG, H.264, AVC
- Max Digital Video Resolution
- 1280 x 960
- Motion Detection
- Exposure Range
- 2 sec - 1/24500 sec
- Digital Video Capture Resolution
- 1280 x 960, 160 x 90
- Frame Rate (max)
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/3"
Lens Construction
- Vari-focal
- Optical Zoom
- 3.6 x
- Focal Length
- 3.3 mm - 12 mm
- Lens Iris
- F/1.4
- Horizontal Field of View (degree)
- 24 - 82
Panning
- Range (degree)
- 360
Tilting
- Range (degree)
- 170
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, IGMP, QOS
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm
- Supported Memory Cards
- SDXC Memory Card
- C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, IEC 60068-2-27, IEC 60068-2-64, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, IEC 62262 IK10, EN 62471:2008
- White
- Power Requirements
- PoE Plus
- Power Device
- 12.1 Watt
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- 0 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
