Axis P3344-VE 6mm SVGA, day/night
Quicklinx: 67M4WS00 Mfr#: 0325-001
AXIS P3344-VE network camera is a vandal-resistant, outdoor-ready fixed dome offering superb video quality with wide dynamic range in HDTV 720p/1MP resolution, providing multiple H.264 and Motion JPEG streams, in full frame rate or individually configured. AXIS P3344-VE is designed for easy installation with Power over Ethernet and unique remote focus, zoom and pixel counter capabilities. The camera features day/night functionality, two-way audio and an SD/SDHC card slot for optional local storage. Video intelligence includes video motion detection, audio detection and active tampering alarm. AXIS P3344-VE is perfectly suited for areas such as train stations, university campuses and retail stores.
  • High-performance video
    The AXIS P3344-VE Fixed Dome Network Camera offers 1MP or HDTV 720p in compliance with the SMPTE standard in resolution, color representation and frame rate. Wide dynamic range and day/night functionality enable clear images both in daylight and in dark lighting conditions. Remote zoom ensures that the viewing angle is optimized for the scene and required pixel resolution at installation. The remote focus function makes the installation convenient, eliminating the need for focusing at the camera position.
  • Optimized use of bandwidth and storage
    Multiple H.264 streams, as well as motion JPEG streams, can be provided simultaneously either in full frame rate or individually optimized for different quality needs and bandwidth constraints.
  • Vandal-resistant and weather-proof installations
    AXIS P3344-VE with its weather-proof and vandal-resistant casing is a fixed dome perfectly adapted for harsh environments. The camera operates in -40 °C (-40 °F) to +55 °C (+131 °F), powered by standard Power over Ethernet (IEEE 802.3af) only. It is the perfect solution for video surveillance systems in areas with tough quality and efficiency requirements such as university campuses, railway stations and subways.
AXIS P3344-VE Fixed Dome Network Camera - network surveillance camera - dome
Network surveillance camera - fixed - dome - outdoor - vandal / weatherproof
Audio
Yes: two-way audio capability
17.8 cm x 17.8 cm x 11 cm
1.4 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
2.4 x
Max Resolution
1280 x 800
Motion Detection
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
0.3 lux - colour - F1.4 , 0.05 lux - B&W - F1.4
Focal Length Control
Vari-focal
Focal Length
2.5 mm - 6 mm
Lens Iris
F/1.4 - auto iris (DC)
Panning Range (degree)
360
Tilting Range (degree)
170
Ethernet 10Base-T/100Base-TX
1 - network cable - 5 m
Voltage
PoE
Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, auto exposure control, colour control, brightness control, Power over Ethernet, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), SDHC-card slot, AXIS Video Hosting System (AVHS), Open Network Video Interface Forum (ONVIF), Motion Detection Technology, infrared cut filter, Privacy Mask Function, Audio Detect
3-year warranty
Environmental Parameters (operating)
-40 °C - 55 °C; 10 - 100% relative humidity
Audio Support
Dome
Wired
17.8 cm
17.8 cm
11 cm
1.4 kg
Camera
Colour - Day&Night - fixed - outdoor - vandal / weatherproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 800
Motion Detection
Exposure Range
1/6 sec - 1/25000 sec
Video Capture
1280 x 800 @ 30 fps , 160 x 90 @ 30 fps
RAM
128 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/4"
Lens Construction
Vari-focal
Optical Zoom
2.4 x
Focal Length
2.5 mm - 6 mm
Lens Iris
F/1.4 auto iris (DC)
Horizontal Field of View (degree)
40 - 87
Panning
Range (degree)
360
Tilting
Range (degree)
170
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
Interfaces Details
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm
Mounting bracket
1 x network cable - 5 m
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, NEMA Type 4X, EN 61000-6-2, EN 60950-1, EN 50121-4, IEC 62236-4
Power Requirements
PoE
Software Included
Drivers & Utilities
Limited warranty - 3 years
-40 °C
55 °C
Relative Humidity (operating)
10 - 100%
